shacked sequence
hi there...
i have a simple question..
i have a stacked sequence. 5 frames...
frame 0....start to test device
frame 1....check reading
frame 2....verify reading, if good, frame 3, IF NOT...HOW DO I GO TO FRAME 0?
frame 3....record values
frame 4....output values...
I don't think I want to move toward state diagram at this time..can i still achieve what i want with the frames I have. i want to change the less code the better.
can someone give me some sugguestions...
Message Edited by krispiekream on 12-12-2008 06:39 PM
Krispiekream
(3,518 Views)
Accepted by topic author krispiekream
You really need a state machine.  If you refuse to make your life easier, then you need to create a sequence local and pass the boolean out of frame 2.  Use a case structure to not do frame 3 and 4.
(3,513 Views)
yeah..hahaha....i havent learn how to do state machine yet...
i just want the quickest and easiest way out so that i get this whole validation thing out of the way..
i can mess with more programming when QA is not sitting behind me..
thanks..i think your idea is what i was looking for...
Message Edited by krispiekream on 12-12-2008 07:07 PM
Krispiekream
(3,508 Views)
Message Edited by krispiekream on 12-12-2008 07:34 PM
Krispiekream
(3,497 Views)
