shared data problem in state machine
I have a state machine with each state reading one byte from serial port. The bytes read in state 1, 2, 3, 4 combines an unsigned 32-bit number.
How to store the bytes read from different state and combine them together in the end, without having unwired tunnel problem?
(2,887 Views)
Shift registers.
But why would you read one byte in each of 4 different states?  That's like reading a book a letter at a time.  I would read all 4 bytes in a single state.
(2,877 Views)
Yes, I decided to read 4 bytes at a time instead. Thanks.
(2,863 Views)
