shared folder acces
Hi everyone,
i need to know if there is a labview fonction that allow me to controle the acces of a shared folder. In other words, can i make a shared folder accesible with a login and a password
thanks
(2,657 Views)
Hi Brainiac,
is this folder located on your computer or on a server?
When it is on your computer you may try to call some command shell (or Powershell) batch files to control access right for this folder.
If it's on a server you need to talk to the admin of this server…
(2,629 Views)
