shared variable browse in a web published remote panel
Hallo,
I have made a simple VI where the user can select a shared variable and show the current value.
I use a shared variable control to let the user select the variable from the panel.
Everything run smooth if I interact directly on the server where the VI is running.
This VI is published on the web and when I access the VI form a web browser I cannot browse the shared variable list.
The pull down control is empty and the 'browse' text is disabled.
Is there any option to have the shared variable list browsable on the web published panel ?
I think this should be possbile since the VI is running on the server where variables are published.
thank you
Gianpiero
(2,966 Views)
Hi
I suppose you used the shared variable control to implement your vi. In this case i have to inform you are using a ActiveX control that related to LabVIEW remote front panel shows some limitations.
For more details i suggest you to visit this link which contains a list of the limitations you should keep.
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/21b9a9c913f54f918625703d004d6fd9?OpenDocument
regards
Logan
Matteo
(2,941 Views)
Logan,
Thank you fot the reply, but the link is broken or maybe not reachable.
Could you suggest a method to browse shared variables in a web published panel ?
regards
Gianpiero
(2,935 Views)
Sorry
This is the right link
http://digital.ni.com/public.nsf/allkb/21B9A9C913F54F918625703D004D6FD9?OpenDocument
Logan
Matteo
(2,932 Views)
