shared variable cluster containing 'path' variable produces syntax error
I have come across a strange error while passing a custom typedef via shared variables in LV8.2.
It seems that if the custom control contains a 'path' variable within a cluster (and the path is NOT THE ONLY variable), writing to the shared variable produces a runtime "syntax error" that cannot be handled.
I have included a simple project that demonstrates this.  There are two custom controls.  Both are clusters containing a path.  One has ONLY a path, the other has a path and a numeric.  The control w/ ONLY a path seems to work fine went passed via shared variables.  The control w/ path AND numeric produces syntax error.
It seems that paths are not really supported with shared variables, which is not too big of a deal considering strings work just fine.  But, it is strange that a path in a cluster by itself works fine.  Add something else to the cluster and you have problems.
Could someone at NI verify this and submit a bug report?
Thanks..   Off to fill my code with path->string conversions    ...doh!   😉
(2,913 Views)
Hi WHAVEman,
This was reported to R&D (46AE2NX6) for further investigation.  It seems that you have a suitable workaround (using string controls instead of file paths).  Thanks for the feedback!!
Ching P.
DAQ and Academic Hardware R&D
(2,889 Views)
