shared variable does not work in executable
In editor mode, the shared variables update fine.  When I build the executable, the shared variables no longer work.
See attachment.
Message 1 of 16
(5,479 Views)
What error code are you getting?
Do you need to create the whole process and DB on the fly?  If not then define in the project and just programmatically deploy.
Message 2 of 16
(5,442 Views)
Yes, I need to create the whole process and DB on the fly!
And error code is: -1967361997  "Property Node (arg 1) in NI_DSC.lvlib:Configure Scaling (Shared Variable).vi->NI_DSC.lvlib:Configure Scaling.vi->TestCitadel.vi"
So, as I said the code works properly in edit mode but does not work in executable...
Message 3 of 16
(5,414 Views)
I found this note in the LV2010 help, I wonder if this could be related to your problem...
Note  You can use scaling only for network-published shared variables, I/O variables, or I/O aliases. When the shared variable you want to scale is a network-published shared variable, it must have a data source. Configure a network-published shared variable to have a data source by placing a checkmark in the Enable Aliasing checkbox on the Variable page of the Shared Variable Properties dialog box.
Message 4 of 16
(5,406 Views)
I wrote that it does not work in the executable. Where's the difference?..
Message 5 of 16
(5,400 Views)
The whole idea behind NSV scaling is to apply it to a source and then have it appear as a scaled value in the destination.
I do not see that you are using it that way.
Message 6 of 16
(5,393 Views)
could you make an example vi?
Message 7 of 16
(5,390 Views)
Could you fill us in on what you are trying to do?  What data are you trying to scale?
Message 8 of 16
(5,382 Views)
Could be the reason that I use LV2010 (to make the executable) and DSC Run-Time 2009 on the target PC?
Message 9 of 16
(5,381 Views)
I need to create/delete/modify in the citadel database about 500 tags on the fly. And it should be scaled and so on etc...
Message 10 of 16
(5,374 Views)
