shared variable error
HI,
I get this error,
LabVIEW: (Hex 0x8BBB0005) Unable to locate variable in the Shared Variable Engine. Deployment of this variable may have failed.
This error or warning occurred while reading the following Shared Variable:
\\RT Single-Board RIO\temp1_lib\Temperature1
\\192.168.1.140\temp1_lib\Temperature1
What do I need to do?
(3,276 Views)
Are you deploying the variable? Right click on the library>deploy.
PaulG.
Retired
(3,264 Views)
