10-13-2015 03:58 AM - edited 10-13-2015 04:00 AM
I have a LabVIEW 2015 application where I have written to a shared variable from another computer.
In Distributed System Manager I see on target that the SV-value (2) is received under Network Items, but not under
localhost. How do I handle this, so it is also received under localhost ?
Martin
10-13-2015
04:50 AM
- last edited on
06-10-2026
08:30 AM
by
Content Cleaner
A quick google search found this article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHvgCAG&l=en-US
10-13-2015 05:41 AM
Unfortunately that article gives me nothing related to this problem, as far as I can see.
10-13-2015 05:45 AM - edited 10-13-2015 05:51 AM
Did you enable aliasing and go through the binding process as described in the article? If not, you need to do that to link the shared variables to the other computer.
If you have done that, then it's probably a firewall / network configuration issue.
When you write to the shared variable, I believe the change should be reflected on the local shared variable engine and then through the aliasing it is applied to the remote shared variable engine.
Edit: Apologies - I had misread your post and thought you were able to write to localhost but not to the remote computer, not the other way around.
10-13-2015
08:29 AM
- last edited on
06-10-2026
08:30 AM
by
Content Cleaner
It is possible to see the same problem looking at the example attached to the article at
http://www.ni.com/white-paper/5715/en/
When I download and test this little example, I have to re-point the bound shared variables on computer2
towards computer1. However, on computer 1, the shared variable library is only deployed on the localhost, not on the net,
making this impossible. So how do I solve this ?
Martin
