shared variable
I use shared variable to transfer data from PXI to a PC. In the PXI the data is right, but when it is transfered to the PC the data is different. I set the buffer of the shared variable 10000, but the data is also different. How can I solve it?
Thank you!
(2,976 Views)
Can you provide anymore information about your application and the issue you are encountering. I can't provide much help with the information provided.
--J.D.
(2,926 Views)
