shared variables values saved in library?
Is there any way to save the last value of a shared variable to the library file so that this value can be accessed next time the vi is run, even if the cRIO module has been powered off in between?
I am writing an application and I need to access previous values of some shared variables. I was working on saving the values I need to a .ini file so that they can be retrieved later, but I thought it would be much simpler if only the value of shared variables was kept over power cycles. I looked at the library file and it is an xml file. I can't imagine it would be that difficult to include this as an option.
Any ideas or comments?
Thank you.
(2,872 Views)
I don't believe that's possible. Here are some posts that might help understand:
forum post 1
forum post 2
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,858 Views)
