shared varibales in a stand alone application
I hve problem with my stand alone application. I have two questions, should I include the shared variables as a file? And, should I include the dependencies?? I get the exe.-file to work properly at the computer where I build the stand alone application, but maybe is it just because I have Labview 8.0  istalled. But I can't get it to work at the computer where I don't have Labview istalled.
Thank you!
(2,790 Views)
did you have labview run time engine installed on the other computer
(2,777 Views)
yes I have it installed. at least, I include the run time engine when I build my installer. I think the promblem is with the shared variables that the program contain. I have seen some notes about not to include the .lvlib in the executable..... but I don't get it to work, the program is running on "the other" computer, where I run the setup and exe-file, but the shared variables can't be found.....
Any ideas here?? I appriciate it!
(2,772 Views)
Hello Frida!
Please look at this document:
http://digital.ni.com/public.nsf/websearch/04D9A85B6967EE87862571140065EEC6?OpenDocument
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(2,762 Views)
