sharing an analog input across multiple application vis.
Have a single devicel, a USB-6343 here and 4  Vis running as seperate executeables..  but they all need different channels off that device (D I/O, AI/O, counters).   This works except when it gets to the analog inputs.   I sort of aware that due to the single ADCs, you can't have multiple tasks doing the analog inputs.  When I was doing a single Vi, I made a single task that polled NChan1Samp , and then unpacked the cluster and used them for various purposes.  It sort of skipped my mind when I ran multuple copies of this Vi , it wouldn't work.
My first attempt at getting around this was creating a DAQmx Task in NI Max that would pull 6 analogs, and change the VIs to each read from this DaqMx Task, but be concerned with different indexes.    That failed.. same results as if i had different threads directly trying to access the analogs (1st one gets it, rest done).
Is there something else I can try?  I have thought I could make a dedicated Vi that becomes a server for the analogs via shared variables?  Anything simpler than this?  I haven't used the shared variable thing yet so would have to figure that out first.
(2,772 Views)
Create one process that reads all the data an publishes it to the 3 consumers using a user-defined event (UDE). Sort of a producer-consumer pattern but with three consumers and using an event rather than a queue.
When in a situation where you have multiple consumers that all need to see the same data, you need to use a UDE. A queue will divvy up the data so any one consumer will only get every third update.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,747 Views)
That doesn't really let me jump .EXE files though right?    My situation is I'm launching 4 instances of the same Vi in executable form.    Each one, via .csv config file is looking at a different set of Analog inputs.  However, because only 1 thread is allowed to talk to analog inputs as a whole due to a single ADC chip in the single USB DAQ.. I have to figure out how to share the hardware (ADC chip, not Analog channel).   I thought making the task in NI Max that looks at all 8 analog channels, and then each VI.exe only looking at the channels they need from the NI MAX task (thus, only 1 task really accessing the hardware) would work.. but didn't.
(2,741 Views)
Ok, if the separate processes are executables, substitute TCP/IP connection for UDE and carry on. There are some very good example for multi-connection TCP/IP shipping with LV.
Mike...
LabVIEW Champion
(2,734 Views)
