sharing data between loops
Here is the VI I used, the step led light indicates the number of steps, the problem is I can see the values changing in the "elements" indicator but not being updated in the "period" indicator. It would be great if someone could shed some light on this.
Message 11 of 12
(828 Views)
If you are trying to run this on a Windows machine, then your top timed loop will not run.  There is no 1MHz clock available on a Windows system, on the 1kHz.
Message 12 of 12
(818 Views)
