shift register didn't add
Dear all,
I am trying to use shift register adding all the detected waveform together. The added result will be divided the present number of waveform to get the average result. However, it looks like the shift register doesn't function at all. Refer to the image below, if the number waveform is 1000, the intensity of the averaged signal is just 1/1000 of the detected signal. Theoreically, if no noise present and the shift register did add each detection together, the average signal should be identical to the detected signal. Anyone can help me resolve this problem?
Thank you very much
(3,325 Views)
Accepted by topic author KevinLilian
First you should be dividing by the N of the inner loop, not i+1 of the outer loop.
If you want to average over the outer loop as well, you need a shift register in that loop.
Lynn
(3,320 Views)
Hi, Lynn,
Thank you very much for your reply. I've changed the connection. However, It looks like the average signal just follow the detected signal. Still no averaging happening.... 😞
Chuan
(3,313 Views)
Can you post your VI with some data saved as default? That we we can look at what is happening.
Is your data acquisition triggered in such a way that each waveform is in phase?
Lynn
(3,305 Views)
I just got it fixed. 🙂
The reason is once the inside "for" loop finished, the shift register will get refreshed again. That's why I keep seeing the averaged signal just following the input signal.
A solution would be deleting the inside "for" loop and adding the shift register directly on the outside loop.
Thank you very much, Lynn
All the best,
Chuan
(3,300 Views)
Then you should mark Lynn's message 2 as the solution to your problem rather than your own thank you message.  First you will have to go to the options menu to the upper right of your message to unmark it as the solution.
(3,280 Views)
I don't mean to make any offense. I just thought that I should post a more straightforward and clear explanation. Anyway
(3,249 Views)
