shorter time delay
hi, i'm a new user of labview and using labview 7.0. i would like to make delay between steps, and using time delay function. but it seems like it can only delay for minimum 1 second. is there any other way to delay shorter time? hope some body can help me
(2,888 Views)
Why do think the minimum delay is only 1 second? The time delay input is a DBL. If you want a delay of 10 milliseconds, you would enter a value of .01. A value of 100 milliseconds is entered as .1.
Don't count on much more than a 5 millisecond (.005) resolution, though.  Windows is not that deterministic.
(2,886 Views)
Another thing to add:
Since you are new to LV and speak of "steps", i give a recommendation to you:
Do not use Sequence Structures (nor variables)!
Norbert
Norbert
Expert: Geometry
(2,879 Views)
