should i require (1x)control module in communication of AB,MessungPLC & CFP NI on ethernetTCP/IP network if i using DSC Module
If I using Datalogging & Supervisory Ctrl Module for communication of allen bradly plc,messung,cfp NI,on the ethernet TCP/IP,can i require LabVIEW 8.2.1 ,Run-Time (1x) Ctrl Module
(4,901 Views)
I am not sure of your question.  Can you please elaborate?
Thanks!
(4,849 Views)
