show LEDs from arudino in labview frontpanel?
Hi I have a fairly simple question. I have some LEDs on my breadboard connected to an Arduino UNO. Red LED is turned ON when moisture level is below certain threshold and a water pump starts to run, when the moisture level is sufficent a green LED is turned ON.
I wonder how I get these LEDs transferred and shown on to the Labrview frontpanel?
(3,225 Views)
Who wrote the code running on the arduino? Are you using linx?
(3,217 Views)
I have mostly made the code my self in Arduino. I am already transferring measurement data (temperature, moisture,humidity light intensity) through VISA Resource---->Serial VISA block etc.
But LED is a boolean value, so a bit unsure how to transfer that?
(3,193 Views)
You can transfer it as a number. 0=FALSE and 1=TRUE. Then convert it to a boolean use "not equal zero" from the comparison palette.
(3,188 Views)
