show connector sub vi connections
Hello MeCoOp,
just make a control out of the path constant. That should do it.
If you don't trust the user, you have to check this control for validity 🙂
And don't forget to initialize the path control to a correct path ("make data value default" or use a local).
Message Edited by GerdW on 07-20-2005 04:06 PM
Message 11 of 12
(533 Views)
Rather than using a constant for the path, use the built-in LV "File Dialog" function and make sure that the "Select Mode (2)" input is set to "existing dir" or 3. This will allow them to specify a path but not be able to change the file name.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(524 Views)
