show different plots on chart legend
I was wondering if there's anyway to control which plots show up on the plot legend.  I have created a graph that can display different plots (by making different sets of plots visible and the rest no visible) but I can't figure out a way for the plot legend to change with me... I see property nodes to manipulate it's height and position... I can use property nodes to show more plots on the legend, but it will always start at the 1st plot... if I have 2 sets of plot
set 1 = plot 1, plot 2, plot 3
set 2 = plot 4, plot5, plot 6
and I choose to make only set 2 visible
I would like the legend to show plot 4, plot 5 and plot 6 (without showing plots 1,2, and 3).... but I can't figure out how to do this, is it possible?
much thanks!
(2,534 Views)
It is the property name plot.name. Be careful how you fill the name in because the order that is displayed. If you make 3 invisible but want to change the name for 4, I am not sure, but I suspect that it will change the plot name 4.
(2,518 Views)
