show front panel in runtime
I want to show front panel in runtime( or when called) without all the
menus, tool bars and scroll bar, just as a ordinary control panel only
with window title.
any suggest will be appreciated.
Jacob
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,535 Views)
> with window title.
> Jacob
These are options you can setup using the Sub-VI Setup.
You can also access these through the VI Server.
If you look on NI's web site and get the Splash Screen VI
you can see how to do this.
I can't get to LAbview right now or I would be more specific.
(5,535 Views)
Use the VI Setup (from the VI icon in the upper right corner) - Window
dialog box, and set up the behaviour of the front panel as desired.
Morten Brochs
morten.brohcs@natech.no
skrev i meldingsnyheter:7jovj8$p2e$1@nnrp1.deja.com...
> with window title.
> Jacob
(5,535 Views)
