show graph that is created in a subvi
Here are pdf prints of my code. The VI file calls a sub VI on the right and attempts to retrieve data which can be graphed.  The Sub VI shows how I'm attempting to dump data retrieved from an oscilloscope into an array of doubles, which I then hope to be able to access and graph from a Higher level VI.
My problem Is I have a book that tells me how to deliver info into a sub VI, but not retrieve output data.
Thanks - Matt
Message 11 of 33
(3,288 Views)
Yes, there is data shown in the array when I run the Sub VI independently.
-Matt
Message 12 of 33
(3,287 Views)
Hi Matt,
You may want to check out this Developer Zone article on SubVIs.
Developer Zone Tutorial: SubVIs
http://zone.ni.com/devzone/cda/tut/p/id/7593
Specifically, you may want to read the section on Assigning Terminals to Controls and Indicators.  Thanks!
Message Edited by StarsHockey on 02-05-2009 01:00 PM
Stephen Meserve
Message 13 of 33
(3,264 Views)
Thanks Steven, I've looked at this document before.
If I understand correctly, in order to take data from a sub VI and use it in a VI I must create some form of indicator in the sub VI. In my case my indicator is an array of numeric indicators and cannot be a waveform.  I then wire/connect that indicator to a terminal of my Sub VI.
From there I can have my VI call the Sub VI and attach a waveform up to the output terminal (linked to the array) of my sub VI.
Am I missing something? It seems this should work unless theres some specific trick to using data held in an array with a waveform graph.
-Matt
Message 14 of 33
(3,245 Views)
Hi Matt,
I think you've got a good grasp of it!
Stephen Meserve
Message 15 of 33
(3,241 Views)
Great... but what does it take to obtain data from my sub VI.  I've also tried outputting to an array in my VI instead of a waveform using the data from my sub VI. This produced no data in my array.
Thanks - Matt
Message 16 of 33
(3,230 Views)
Hi Matt,
I've attached a simple example of building a subVI passing arrays.
Stephen Meserve
Message 17 of 33
(3,216 Views)
Hi, I think I'm getting close to doing what I want to do.
> 6) Next, I created a VI server reference by selecting "Programming" "application control" "VI server reference".  Right clicked on the "Server Reference" and choose "Link to" "Pane" "Waveform plot"
I'm using LabVIEW 7.0, and it appears that there is no such thing as a "VI server reference" (unless it's hidden in a place other than the one mentioned above). What can I do in this case?
I'd really appreciate any help.
Hong
Message 18 of 33
(2,819 Views)
Hi Matt,
When you wire the array to an output terminal on a subVI without wiring it to a waveform indicator, does the main VI run? Are you able to attach any kind of indicator to the output array other than the waveform?
- Regards,
Beutlich
Message 19 of 33
(2,786 Views)
It could be a problem with either the terminal connection passing data or the waveform graph. You might try debugging steps like attaching other kinds of indicators to the subVI and attaching constants to the waveform.
- Regards,
Beutlich
Message 20 of 33
(2,769 Views)
