show highlight execution button
Hi there,
I wish to ask a basic question about highlight execution and retain wire values. I know that the buttons should normally be placed on the toolbar, however, in the case they are not there, where can I click to make them reappear? thanks!
Best
Harry
(4,260 Views)
Accepted by topic author Harry Yang
You probably have debugging disabled. Go into the VI properties under execution and see if Allow Debugging is checked.
LabVIEW 2012
(4,258 Views)
Thanks a lot! That solves the problem.
(4,252 Views)
Thank you very much. 🙂
(3,577 Views)
