I have a tab control layout in which an xy graph is on one tab and the inputs for it are on the other. Ive set up the cursors on the xy graph to show names, although when i add a cursor, then look at it on the other tab, i see the name twice, once above the cursor and one over top of it. If i tab back over to my controls, and then back to the xy graph, this problem is fixed and i can then see the name correctly, once, above the cursor. Same thing goes for if I switch windows to IE forinstance or anyhting else in windows. Sounds like a display refresh problem, but im not quite sure how to fix it. If anyone knows how I can solve this, please let me know.
Mark
