show selection property
Does anyone knows how to access the 'show selection' option programmatically.
As far as I know it is only accessible via Right click->Advanced->Show selection.
Ton
My LabVIEW Ideas
(3,523 Views)
To do this porgrammicly all you have to do is right click on the control or indicator that you are trying to make visible and create a property node. One of the properties will be visible attach a true constant to the property in write mode. That should be all you need to do.
Tim
GHSP
(3,505 Views)
Hi Timothy,
I meant this option:
which I can't find programmatically.
What I now do is enable it manually and set the selection off-screen but that is not a good method.
Ton
Message Edited by TonP on 01-16-2008 09:39 AM
My LabVIEW Ideas
(3,492 Views)
TonP,
I think you mean the Show Selection property of a Tabl, right... ?! Smiley Happy
Yeah, it is not accessible programmatically still now, I mean in 8.5 also. Smiley Sad
- Partha ( CLD until Oct 2027 🙂 )
(3,483 Views)
Sorry TonP!
I got that ypu meant an array, but try for Table also, it is not there.
Also, for Listbox & Multicolumn Listbox, a ferw of teh properties are only settable as statically, not programmatically. Smiley Sad
(3,481 Views)
