shutter control with APT driver
Hello
I am quite new to Labview. I'd like to remote control a shutter SH1 with tsc001 controller within a Labview VI.
I have seen that one can use the activex objects to insert an APT driver in a Labview VI (thorlabs drivers for motion control, see http://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf, and http://www.thorlabs.com/tutorials/APTProgramming.cfm). Unfortunately, there are many activex objects (APT Chopper / laser / motor / tec controls) but not the shutter control that I need.
can anyone please help me? thanks a lot
Damiano
(4,497 Views)
I have come to know that I should use the APTPZmotor activex object.
I have tried but it does not work. I think it does not recognize the serial number, which is right (it is both on the physical device and on the APT software interface). I attach the image of the VI I wrote copying a standard one.
The VI runs, but I get an error in the APTPZmotor interface and I cannot give it any command. Furthermore, the serial number on this interface is not the one I insert from the serial number property node (that's why I think the problem is on the HWSerialNumber property node).
thanks for our help
Damiano
(4,483 Views)
Accepted by topic author dgen
Thorlabs gave me the answer, here it is if anyone should meet the same troubles: to communicate with a tsc001 solenoid shutter control one should use the MG17motor activex object, instead of APTPZMotor. Then everything will work fine.
D
(4,479 Views)
