sick lms 100 output front panel
Hi i am working on sick lms 100 laser scanner. I am able to communciate with all the stuffs and run the program in labview. My final output is shown below but the problem is as far as i know, the laser scanner gives the distance and angle. The distance should be in mm but i am obtaining the array of distance of huge unit which is not correct. Can anybody explain me, why i am obtaining this result?
(2,926 Views)
I would say "Read the Manual".
The numbers you show look like they are integer values well within the range of a U16/I16, or U32/I32.  They are probably being sent as integers and need to scaled to meaningful engineering units.
(2,898 Views)
but how can we covert it into desired value. Give me some idea.
(2,894 Views)
y = m*x + b
(2,891 Views)
