^ sign
My english is poor, sorry. I don't know the word for this sign --> ^
I can't find it in labview..
For example: 3^3 = 27 = 3*3*3
Message 1 of 9
(4,545 Views)
Search Power of X into the Logarithmic subpalette of the Numeric palette
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 2 of 9
(4,535 Views)
It is called Power Of X
Computes x raised to the y power. If x is not complex, it must be greater than zero unless y is an integer value.
Otherwise, the result is NaN. If y is zero, x^y is 1 for all values of x, including zero.
The connector pane displays the default data types for this polymorphic function.
Karthik SP
Message 3 of 9
(4,534 Views)
Thank you
i've got it! Smiley Happy
Message 4 of 9
(4,530 Views)
Hi Karthik,
You re wrong absolutely, I m afraid to say...
0 raised to the power of 0 is NOT 0, but it is an indeterminate form.
Please read the following link -->> http://www.math.utah.edu/~pa/math/0to0.html
Search google for "Indeterminate form", you ll know more of them. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 9
(4,522 Views)
Message 6 of 9
(4,520 Views)
Hello Partha,
"0 raised to the power of 0 is NOT 0, but it is an indeterminate form"
I know that zero (power of) zero is undefined but...
In LabVIEW when you use "power of X"
function with its both the input as zero ,resultant is ONE.Smiley Happy
Karthik SP
Karthik SP
Message 7 of 9
(4,509 Views)
Hmmm... Now I understand that you had copied & pasted the LV Help contents... Smiley Wink
Message 8 of 9
(4,495 Views)
took too much timeSmiley Very Happy
Karthik SP
Message 9 of 9
(4,492 Views)
