signal display
Hello
i have a problem with the graph on labview.
For example, I generate a sine signal with a frequency of 50hz, I want to display it on a graph, but I do not see the sinusoidal signal.
I want to know how to change the x-axis to display the correct time (0.02 seconds for a period) and the amplitude on the Y axis
Thank you !
(3,391 Views)
please always attach what you tried to do as a VI, otherwise it is hard to critique your code.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,387 Views)
Did you look at any of the examples that ship with LabVIEW?  Have you looked at tutorials, textbooks, lectures, etc. that discuss graphing signals?  Do you have code (to show us) that "doesn't work"?  Is this Homework Due Tomorrow?
Bob Schor
(3,341 Views)
i solved the problem, thank you
(3,318 Views)
