signal generation and measurement using VRTS
Hallo,
I am trying to generate a CW signal and measure  it using VRTS. The signal generation and measrement is done through VST.
from my readings i understood that the software options such as RFSG and RFSA is able to generate and measure it.
I want to use both the drivers and build a software tool for my use case.
some steps during building labview are :
  1. Genreation of signal usig RFSG
  2. measurement of signal using RFSA
i saw some example VIs of RFSG and RFSA, but i couldn't find a combined example for my use case
which pattern will be useful for my use case?state machine, P/c,or advanced frameworks?(I am learning labview through projects.not an advanced user)
how to plot the measured data as power vs frequency?How can i save the measured data?
Message 1 of 1
(857 Views)
