signal generation frequency
Hi, now I am using the labview with myRio to generate PWM signal.
In order to figure out operating labview with myrio, I have tested some simple things.
What I found in the signal generation module is the frequency in labview is totally different the frequency of real time which is shown by ocsilloscope.
For example, let's assume that I generated sine wave form(amaplitude is 1)
if I put the 10.1(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 10s(time)
if I put the 100.1(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 2.5s(time)
if I put the 10.2(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 5s(time)
if I put the 10.3(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 3.32s(time)
if I put the 10.4(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 2.5s(time)
if I put the 1.4(hz) as a frequency in labview, then real time frequency in oscilloscope measurement value was 716ms(time)
I can't find any rules from here.
How can I match up the frequency in labview with real time frequency measured by ocsilloscope.
also how can I generate sinewave form with high frequency such as 1Mhz or 100kHz etc..
Please help me.
I have attached my file.
(2,613 Views)
Can you save your VI in version 2012 and re-post it.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,604 Views)
Thank you for your reply.
Since I don't have Labview2012, I attached my problem with word file.
This is very simple topologies and I just want to generate same frequency in Labview as real time frequency in oscilloscope.
please check it.
thank you very much!
(2,553 Views)
You can still save you code to previous version.
(2,533 Views)
