signal generation
I want  simulated pulse  with respect to time and voltage, the time and voltage reading are addressed in Pulse.png, i have also attached vi.
Ali
Message 1 of 12
(5,287 Views)
Missing time can be taken as 50ms
Message 2 of 12
(5,285 Views)
Hi ali,
there is a full palette of signal generation functions.
All you need are some ramps…
Message 3 of 12
(5,276 Views)
Hello GerdW,
My requirement is at the time period and voltage has to be defined,
For example
at 50ms the voltage should be 12v, at 100ms the voltage should be 12v,120ms the voltage should be 6v etccc..please find the attached requirement doc, and do the need ful
Ali
Message 4 of 12
(5,266 Views)
The output signal will be given to the daq
Message 5 of 12
(5,262 Views)
yes, i need to give this generated signal to the hardware.
Message 6 of 12
(5,260 Views)
Hi ali,
For example at 50ms the voltage should be 12v, at 100ms the voltage should be 12v,120ms the voltage should be 6v etccc
You need to append the following ramps:
- from 0ms to 50ms from 0V to 12V
- from 50ms to 100ms from 12V to 12V
- from 100ms to 120ms from 12V to 6V
You need a loop, RampPattern and BuildArray…
Choose the timing resolution (dt of a waveform, number of samples for RampPattern) according to your requirements and hardware specs…
Message 7 of 12
(5,253 Views)
Can you please attached an example vi
Message 8 of 12
(5,240 Views)
Hi ali,
here's a simple example:
What have you tried so far?
Where are you stuck?
Message 9 of 12
(5,232 Views)
I have done a vi which is attached and i want to give this output to DAQ but it was throwing error.is there any way to generate a defined signal.
Message 10 of 12
(5,214 Views)
