signal saturated with customer scale
Hi everyone, I have a small problem with labview. I read a voltage signal y=2sin(x) from chanel 0 and display it on a graph indicator, becasue this signal is going after a 100:1 potential transformer, so I 'd like to show it correctly(i.e. in real voltage values) on the graph indicator, I witre the following VI, however, one got saturated and the other one is ok. I want to know where the problem is on the first one. Any suggestions? Thanks a lot!
(3,150 Views)
Hi Acewong,
Could you provide images of the front panels to better demonstrate what you're seeing?
One thing that's a possibility is that your graphs are set to auto-scale with an increment that's too small/large.  Try changing the "Loose Fit" property available in the right-click menu.
Tom L.
(3,134 Views)
Set the voltage range of the DAQmx Create Channel. You've saturated the A/D because the gain is not correct. The range you use should be the scaled values.
(3,118 Views)
Hi, Dennis, I set the range for -10v to +10v,,which is the max range it has.,and for the A/D converter, is there a range for it? It is saturated at about 90 voltages, why 90? Thank you!
(3,108 Views)
Hi,0utlaw, it is not auto scale, i change it to -1000 to +1000, still saturated at 90V .
(3,106 Views)
No. You set it for the max scaled value. Do what I said and change the range. Changing the scale of the graph is silly.
(3,101 Views)
