signal time delay waveforms
I`m using Labview 2009. I wann simulate various signal time delays. Pls find the attachment.
I tried with waveform generator and component tool eg: dt, t0 but `d not simulate my requirement.
Also I tried searching in forum for similar VI but `d not get 4 my requirements.
Pls help.
Manoj
(3,565 Views)
Post you VI and your requirement then we will deal with it
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,559 Views)
Here is my VI.
(3,539 Views)
What you want to do ?
What type of signal you want ?
Let me know someting
--Ranjeet
(3,536 Views)
I`m simulating PTT kinda situation so I have used Digital Random Generator in my VI.
Whenever PTT is pressed (active low), data enable shud be become high after a few delay say T1.
Whenever PTT is pressed (active low), audio signal (sine waveform) shud pass through after a few delay say T2 & so on.
Similarly for rest of the waveforms.
But here `m not able to get a constant delay for all the transitions of 0s & 1s using my VIs inspite of using waveform components like t0, dt.
I was stuck here. So only I didnt proceed with sine waveforms(audio signal).
pls tel me how to go abt dis
Manoj
(3,525 Views)
