silver boolean latch when press action
I tried a silver boolean button with the mechanic action of latch when press in a while loop. But  it acts the same as "switch when press".
No problem with modern style boolean button.
LV2012
(2,632 Views)
I'm not seeing the behavior you are describing.  Can you post some code to demonstrate your issue?
(2,625 Views)
Today I tried again. It looks OK now. Weird.
Thanks.
(2,598 Views)
