simple calculator design
Hi Rupali,
Are you referring to the VI by Andrey? Can you elaborate on the issue you are facing.
Typically you wouldnt be able to add floating point numbers if the data type is an integer. If you have modified the inputs to an integer type in the sample VI please change them to dbl.
Rohit
NI India
Message 11 of 15
(2,149 Views)
Yes, I'm referring to the VI by Andrey... I have modified it.. Now I'll try with this solution to add floating point.... Hope it works.. 🙂
Message 12 of 15
(2,121 Views)
I changed the representation  to dbl... Still it's not working... I'm not able to add floating point... 😞
Message 13 of 15
(2,114 Views)
Hi, I have the same question, I would like to know how to design a calculator with the 10 buttons (0-9) and four buttons for functions- dividing, multiplying, adding, and subtracting. I have only labview 8.2.1, can someone post a labview that can support labview 8.2.1. ?
Message 14 of 15
(2,079 Views)
Dear Rohit
Can we insert windows calculator in LV2011
Anilkumar.G.Kulkarni
Lucas TVS Ltd
Message 15 of 15
(1,222 Views)
