simple error handler dialog box
I am using the simple error handler to determine if a process should stop running (if there is an error) or continue (if there is no error) but I the pop up dialog box prevents the process to continue until the continue button has been pressed.  The context help indicates that the dialog box is optional but I don't see where to change this.  I also tried unchecking tools/options/block diagram/enable automatic error handling dialogs and this didn't work either.
(3,345 Views)
hello,
You don't see the option "type of dialog"?
See the attached picture.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,339 Views)
doh!  I knew it would be something simple.
Thank You!
(3,331 Views)
