simple labview VI functions correctly, but when built into application the serial comms do not function
@Sholyoake wrote:
given this application is very simple and doesn't use bytes at port or anything else, can folks please suggest why it's not functioning?
Because LabVIEW is still open? Your VI might not have closed the reference and LV might still be claiming the VISA resource...
Did you try closing LabVIEW before running the exe?
See Re: simple labview VI functions correctly, but when built into application the serial comms do not f...
Message 11 of 24
(642 Views)
wiebe@CARYA wrote:
Because LabVIEW is still open, and your VI might not have closed the reference, and therefor LV might still be claiming the VISA resource...
yes, I closed labview and rebooted the machine, I've also tried switching to a different COM port...
Message 12 of 24
(641 Views)
turns out my simple VI was working, but just so slowly it looked like it wasn't, only updating the read value every minute or thereabouts.......
Message 13 of 24
(634 Views)
Hi Sholyoake,
So the Vi was working as you programmed it, but maybe not like intended… 😄
Message 14 of 24
(631 Views)
@GerdW wrote:
Hi Sholyoake,
There's always a difference between what you want the code to do and what you tell it to do; as you fix things, the hope is that eventually the two converge to the point where you cannot distinguish one from the other.  😄
Bill
CLD
(Mid-Level minion.)
Message 15 of 24
(626 Views)
@GerdW wrote:
Hi Sholyoake,
I'm only referring to my simple VI from post #10 here, literally opens the VISA reference, writes three characters, reads the response and closes the reference... my issue now is how to make that run more quickly+stably so I can rewrite the rest of the code round it
Message 16 of 24
(624 Views)
@Sholyoake wrote:
@GerdW wrote:
Hi Sholyoake,
I'm sure we could help, but that VI is LV25, and most of us are stuck in older versions.
Message 17 of 24
(581 Views)
wiebe@CARYA wrote:
@Sholyoake wrote:
@GerdW wrote:
Hi Sholyoake,
I was quite happy with LV21 but NI tech support made me upgrade to LV25 'just in case' and it didn't solve my issue
I'll rebuild the VI in LV21 and share it...
Message 18 of 24
(576 Views)
The Visa port is still open in Development blocking the .exe?
Qestit Systems
Certified-LabVIEW-Developer
Message 19 of 24
(406 Views)
but that doesn't explain why it doesn't communicate or throw an error when the development machine has had a full reboot.....
or why it doesn't communicate when run on the deployment target when that machine doesn't even have labview installed, obvs it has runtime engine, NI VISA and NI Serial drivers
Message 20 of 24
(395 Views)
