simple peak detect
I have a waveform that I need to detect peaks & valleys on. I use the peak detector VI.
Attached is my VI with an indicative array of values that I will encounter. The peak detector correctly finds the 3 peaks but doesn't find the 2 valleys in the middle - I don't undertand why.
Those are the 2 I'm most interested in  - the first & last are just tails of the waveform.
Any help would be greatly appreciated,
thanks
ak
(3,239 Views)
Hi cig438,
In order to view all your low points, you need to change your lower-peak-detection to 100.  That should allow you to see all 4 of the lower values.
(3,233 Views)
If I open your vi and set the peak threshold and valley threshold to 100, the peaks and valleys seem to be found.
Randall Pursley
(3,233 Views)
Yes - that does it. Must have been a long week...
Thanks !
(3,216 Views)
