simple pendulum simulation
I've been tasked with the attached problem, with very little training in labview. Could anyone help or give some ideas of where to start im totally lost
(2,343 Views)
I would recommend you learn more about LabVIEW from here. How to Learn LV
(2,340 Views)
The purpose of giving you this Homework and tasking you with doing it using LabVIEW, possibly with some additional "self-study", is to motivate you to learn LabVIEW.  You have a wealth of material in the assignment itself -- it even includes an expression for pendulum position as a function of time (they could have just given you the differential equations and asked you to numerically compute the position, a much more challenging task).
Take advantage of your coursework, the various "Learn LabVIEW" tools on the Web and also listed on the first page of this Forum, and apply yourself!
Bob Schor
(2,274 Views)
Hmmmm   you should really model your simulation on a real system.
Oh! That gravity term suggests that a large mass is nearby.   The correllis effect is going to spin that pendulum unless an even larger mass has a tidal lock on the system.
Extra credit time! Stick your pendulum at a Lagrange point.
Another example of simulating work without any sweat!  At least a pendulum is fairly efficient in a vacuum.
(2,263 Views)
