simple question!
How do I write Labview codes to check an output string. If the string is "XX", "YY", "ZZ" or "XY" then do this. If the string is "AA", "BB", "CC" then do that. I don't want to use the case statement because I have to duplicate the same action for many cases.
(3,102 Views)
Hi;
You do want to use the case structure. What you need is to learn the trick so you don't need to duplicate the same action for many cases. Check the attached VI and see if that is what you are looking for.
Regards;
Enrique
www.vartortech.com
(3,093 Views)
Enrique,
Thank you. That is exactly what I'm looking for. I wasn't aware that each case statement can take more than one condition.
Regards
Dan
(3,065 Views)
