simple "data write in spreadsheet excel 95" question
Hello everyone,
I am facing some problems on my program. Please first read the jpg and my vi.
My ideal program is to add a row and a column into the matrix, and then save the output with [2 decimal points] into [excel 95]
Now the program you see is able to add a row and a column into the matrix, and then save the output [only Int] in to txt format
I try to change from %s to %d to %f, all of them give me [Int] only what I can do?
How can I save it in excel 95 format?
(2,659 Views)
(2,652 Views)
(2,651 Views)
Just replace the Number to Decimal String function with Number to Fractional String. The decimal function only returns an integer with a specified width, and the fractional returns a fractional string with specifed width and precision.
The correct format string for the Array to Spreadsheet function is %s.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,639 Views)
