simple xy graph
Can some one attach an example on how to make a simple graph external input on y axis, current time on the x-axis? Cant find an example.
Cheers
(4,066 Views)
Accepted by topic author ssteel
Here u go.........
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,057 Views)
Ive tried to plot a graph using the same technique as your examples, but its not letting me connect? How do I correct this? What is the difference between what Im trying to do and the example?
Program is attched, attempting to plot the graph at the top of the block diagram.
Cheers
(4,046 Views)
First try to know the difference between XY graph and Waveform charts.Smiley Mad
Balaji PK (CLA)
(4,040 Views)
Iv tried so many different things but I still can't seem to plot the u value from the I/O assistant against the time. I want to just get 1 poit per loop, but it won't let me?What is the simplest way?
(4,014 Views)
