simulate complex impedance
Hi
I would like to plot complex impedance spectra (directly by using complex values), and I may not understand well or make a mistake I do not see.
For instance, for a RC, the impedance should be Z=(RCw-j)/(RCw)
I do not obtain de half of the circle I expect...
thanks for help (I added the vi as well)
Regards
(2,601 Views)
Hi
I do not know what the problem was, by writing differently, it works as it is supposed to :
(2,573 Views)
Hi nitad,
You are now using a completely different formula!?
(2,539 Views)
Hi
Yes, a different formula, but with complex function operations (still I don't know why the first case was not working as I expected).
N
(2,531 Views)
Accepted by topic author nitad54448
Hi nitad,
the first formula was (CRw-i)/CRw, which resolves to 1-i/CRw. That is a line parallel to the imaginary (i) axis!
The 2nd formula describes the expected "circle" in the Re/Im plane…
Btw. you don't need to convert the complex data back to Re/Im arrays to create a plot for your XY graph: the graph can handle complex array data directly!
(2,498 Views)
