simulate strain gauge
Hi everyone, I am currently developing a data acquisition program to measure about 50 strain gauges simulatniously using LabVIEW version 8. At the moment I only have one strain gauge so I would like to simulate the others. I am using the DAQ-MX functions and I am connecting the strain gauges through seven SCXI-1520 cards mounted into a SCXI-1001 box. I don't always have access to the hardware, so I have simulated this hardware setup in MAX but I have been unable to simulate input signals into the simulated hardware to test out my LabVIEW program. I have tried using test panels within MAX to generate an input signal, but when I try to run my program it complains that 'the specific resource is reserved.' Can anyone help me out with this? Thanks in advance.
Message Edited by DarkMarc86 on 04-16-2009 12:19 AM
(4,438 Views)
I forgot to mention, I have tried inputting the analog signal into both the SCXI-1520 and the DAQCard-6036E to no avail. Using the DAQCard-6036E card, the program complains about "device to which the sensor is attached does not have an avaliable internal excitation source."
(4,434 Views)
In case what I'v said isn't very clear, I have used a prodedure similar to the one outlined here:
http://zone.ni.com/devzone/cda/tut/p/id/3698
Except that I am measuring strain and not voltage.
(4,424 Views)
Hi Dark,
           From the devzone article you linked to "Note: NI-DAQmx simulated devices create a noisy sine wave for all analog input channels. Configuration of other simulated data is not available at this time." This means when you're using a simulated device, you don't specify an input signal- you should be seeing a noisy sine wave on all channels. Also,you won't be able to use a test panel to the device and then read from it in LabVIEW at the same time.
(4,397 Views)
