simulated cDAQ
Is it possible to programatically connect to a simulated cDAQ chassis? I do not see a way to configure the ip address in Max.
(3,686 Views)
Accepted by topic author NNS-CAO
There is no IP address because it is simulated.
You can use the simulated module channels in your DAQmx code.
When you connect to a real cDAQ, you configure the IP address for it,
then change your channel assignments to point to the real channels.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,677 Views)
