simulation control sampling time
I'm using control & simulation loop and write  3 waveforms with Write to measurment file (into .lvm). The problem is it wrote 5 times same data (as attached) and made my file very big. Thus, I couldnt plot in excel.
I had try to change sampling time by check and changing input value in Timing Parameters (in Cinfigure simulation parameters) into 1kHz. Also add Create timing souce. But both ways not solve the issue.
Hope somebody can help me. I'm not sure either it is sampling time issue or saving/write to file issue or something else.
Many thanks!!
(3,578 Views)
It's difficult to help debug code we can't see.  Are you able to share it so we can take a look?
(3,561 Views)
Thank you for your concern. I'll update with smaller .vi with open transfer function.
(3,481 Views)
