simulation model converter
hi
i am Youssof, Please help me....
when i click on convert in simulation model converter dialog box the following error appears:
" A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Attached image is the error.
To fix the error, What should I do?
(3,123 Views)
Dear Youssof,
     You've shown us the Error, but not the cause of the Error.  Post the code so we know what you are trying to do, and can (maybe) suggest how to fix it so it does what you want, rather than what you told it to do.  [Note -- I'm assuming that you made a mistake in your code.  However, it could be that you found a bug in LabVIEW -- either way, we need to see the code in order to be helpful].
Bob Schor
(3,099 Views)
