simulation plc in labview
hey guys
I want to simulate a plc lab in labview , I mean we dont have real tools and instrument in our university and i decide to make a virtual edition of those in labview . my question is how can i comunicate between input&output of plc and labview that the student can write a  plc program for a control loop and then test it in labview without using a physical plc   . in additon we want programing for delta products if it's important .thanks in advance for your answer .
(6,061 Views)
This won't be a quick project. You will need a command interpreter -- which means you will need to figure out which plc you want to emulate.
So the point of the class is learning plcs?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,031 Views)
 yes, the purpose of the class is learning plc
i just want to know how i can use plc program in labview for example if one of output is set then 1 actuator will be active . how i should connect the output to actuator ?
(6,019 Views)
If you used Google to do a search for 'plc simulator', you would find numerous hits. Many are free. Check with your instructor if any of these would be suitable. Your time as a student is probably free but if you are new to LabVIEW, I don't see how the weeks to write your own can be justified.
(5,992 Views)
Besides, you should be using a cRIO instead of a PLC.  Then you can program all of your control in LabVIEW!!!
On a more serious note: Way back when I was in college we used a PLC emulator.  It was part of the code editor.  I couldn't tell you whose PLC we were "programming", but it was all written and tested on the lab computer.
(5,866 Views)
