simultaneous analog output 1k sine wave and data acquisition
Although many topics of simultaneous analog output and input can be found in NI Developer Zone, I have not found a case similar to my project. I'm trying to generate a 1kHz sine wave by using the analog output of NI DAQPad-6070E, and acquire one channel input signal simultaneously. I found most of the examples can not work properly above 100Hz. Any suggestions are welcome. Thank you.
Jian
(2,540 Views)
I have sucessfully solve the problem when I observed the increase of
scan backlog number. Simply increase the buffer size of AI/AO and you
can make the 1kHz sine wave output and data acquired properly.
>Jian
(2,540 Views)
