07-01-2008 08:06 AM
07-02-2008 04:40 PM
07-07-2008 06:35 AM
07-08-2008 11:43 AM
Hi murali_vml,
There should be no need for any external connections except for the PFI lines if you choose to use an external trigger. If you want to avoid external connections, you can set up a dummy Analog Output and use the AO start trigger as your trigger source for your 2 counters. I would also like to point out that the use of a counter to trigger your generation is not possible since your board only has 2 counters.
07-10-2008 11:17 PM
Hi Hong,
Thanks once again for support.Actually i was having another Analog output card which has 2 counter channels,that was the reason i was thinking of providing trigger through counter channels.
But anyway AO Start trigger was enough to match my requirement and also i can manage with a single Card.
-Murali
